Tomcat408 Posted April 27, 2011 Report Share Posted April 27, 2011 I just bought a used leisure bay spa. I m just not sure what model number it is the electronic box just says leisure bay it looks like a Hilo but it is a 99 model I think it has an older touch pad that says leisure bay Smart I wish I could put a pic on here if I figure out how I will. I have a leak an trying to find info on it . Any help apreciated Lt. Quote Link to comment Share on other sites More sharing options...
Even Further Posted April 27, 2011 Report Share Posted April 27, 2011 Sign up, create a photobucket account. Upload the pic and post the img link here. photobucket.com link Quote Link to comment Share on other sites More sharing options...
Tomcat408 Posted April 27, 2011 Author Report Share Posted April 27, 2011 Sign up, create a photobucket account. Upload the pic and post the img link here. photobucket.com link Ok here's my pics hope this helps. http://s1106.photobucket.com/albums/h373/Tomcat408/ Quote Link to comment Share on other sites More sharing options...
Tomcat408 Posted April 28, 2011 Author Report Share Posted April 28, 2011 I added pic look at the link http://s1106.photobucket.com/albums/h373/Tomcat408/. Quote Link to comment Share on other sites More sharing options...
PreservedSwine Posted April 28, 2011 Report Share Posted April 28, 2011 Have you determined where it's leaking? Quote Link to comment Share on other sites More sharing options...
Dr. Spa Posted April 28, 2011 Report Share Posted April 28, 2011 Still no picture of the control panel. Quote Link to comment Share on other sites More sharing options...
Tomcat408 Posted April 28, 2011 Author Report Share Posted April 28, 2011 Yes. On the side where the electronic box is there ti a silver pipe looks like it is a heater there is a white pipe that is hooked to it an goes vertical it's about 4inch an it's leaking there someone told me it was a hurricane system not sure but I'm trying to learn this is the first spa I have had . Quote Link to comment Share on other sites More sharing options...
Hillbilly Hot Tub Posted April 28, 2011 Report Share Posted April 28, 2011 Yes. On the side where the electronic box is there ti a silver pipe looks like it is a heater there is a white pipe that is hooked to it an goes vertical it's about 4inch an it's leaking there someone told me it was a hurricane system not sure but I'm trying to learn this is the first spa I have had . Sounds like the heater union is loose, or the gasket in the union is bad. where the white pipe hooks to the silver pipe is a union, try ti tighten it, if that dies not work, you will have to close the gate valves or drain the tub and replace the gasket inside, also check for cracks in the plumbing or on the nut that holds i on. Quote Link to comment Share on other sites More sharing options...
Tomcat408 Posted May 2, 2011 Author Report Share Posted May 2, 2011 Ok I fixed the leak it is taking along time to heat up it's at 73 degrees an climbing about a degree an hour on 110 volt is this common an would I better off chanting it to 220 please give me some advice thanks Quote Link to comment Share on other sites More sharing options...
