afterdark23 Posted September 17, 2010 Report Share Posted September 17, 2010 I have a small leak coming from the safety suction system outlet. from what i have gathered, there is a small hole that "tests" the water pressure. is there a way to plug the outlet hole and not use the safety system or is the only way to fix/patch the leak to buy a new part? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
THE SPA GUY Posted September 25, 2010 Report Share Posted September 25, 2010 I have seen people bypass the switch to make the spa still work , is this the best way to do it ...no I would go get a new safety switch, your is probably a plastic pressure switch. they have a new pressure switch not plastic and holds up much better Quote Link to comment Share on other sites More sharing options...
