CHRIS-in-AZ Posted August 4, 2010 Report Share Posted August 4, 2010 I have a simple question, is it possible to install a variable switch like a dimmer to to my pool motors on off switch to cut the power in half? There is a big push in Arizona to install 2 speed pool pumps saying they could reduce my bill 40 percent. I have a 3 year old Hayward 1.5 hp on a 17000 gallon pool. I typically run it 9 or 10 hours a night after hours so I save on my electric bill which when including AC is 400 dollars a month and my house is only 1600 sq ft. Ive heard I could run it 15 hours on half speed and have clean water and save money, is this true? Ive got dimmers on ceiling fans and they are motors too so it's kind of the same concept. Quote Link to comment Share on other sites More sharing options...
Dr. Spa Posted August 4, 2010 Report Share Posted August 4, 2010 You'd have to use a variable-frequency drive, which adjusts the hertz along with the voltage. Quote Link to comment Share on other sites More sharing options...
waterbear Posted August 4, 2010 Report Share Posted August 4, 2010 Easiest way to do it would be to install a 2 speed motor with the same brake HP as your current motor and wire in a switch to select the speed. AO smith has 2 speed motors that fit most major pump brands and models. http://www.aosmithmo...set.aspx?id=529 Quote Link to comment Share on other sites More sharing options...
mercurial Posted August 5, 2010 Report Share Posted August 5, 2010 9-10 hrs seems excessive for 17000 gallons. I would try running your pump less often if you don't want to buy any new equipment. Quote Link to comment Share on other sites More sharing options...
waterbear Posted August 5, 2010 Report Share Posted August 5, 2010 9-10 hrs seems excessive for 17000 gallons. I would try running your pump less often if you don't want to buy any new equipment. Curious how you can make a statement like this without knowing if the pump is full rated or up rated and what filter it is connected to and what it's flow rate is? Quote Link to comment Share on other sites More sharing options...
