louisd11 Posted June 23, 2010 Report Share Posted June 23, 2010 Hi, I'm trying to fully open my pool up and vacuum it, but my pump is not priming. I've checked the pipes and emptied the air out of the filter, but that didn't help me. I'm not sure but i believe that when we first opened up the pool with the pool guy it was working, but I'm not sure. It takes a while to get to the "almost priming level in the video below" but once it's there the suction is weak. I can't vacuum my pool..HELP. I've checked the following: Filled water in pump Checked for leaks Backwash Clean gaket Emptied air out of the filter Here are 2 videos of my system: This one shows the problem: This video shows somewhat of my setup: Quote Link to comment Share on other sites More sharing options...
quantumchromodynamics Posted June 24, 2010 Report Share Posted June 24, 2010 It looks like your pump basket is in backward. Did I see a pipe running right across the heater? Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted June 24, 2010 Report Share Posted June 24, 2010 You gotta be kidding me... Quote Link to comment Share on other sites More sharing options...
tub_repair_guy Posted June 24, 2010 Report Share Posted June 24, 2010 LOL thats quite the set up! My bet is on a damaged/missing gasket on the lid, unions or shut offs. Check the drain plug gaskets also. Quote Link to comment Share on other sites More sharing options...
quantumchromodynamics Posted June 24, 2010 Report Share Posted June 24, 2010 The basket is definitely in backwards. The back is wider than the front. When you try to put the basket in backwards, it does not go all of the way down and it blocks the flow of water. There is probably debris in the impeller due to the basket not being put in correctly. Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted June 24, 2010 Report Share Posted June 24, 2010 The basket is definitely in backwards. The back is wider than the front. When you try to put the basket in backwards, it does not go all of the way down and it blocks the flow of water. There is probably debris in the impeller due to the basket not being put in correctly. +1 Quote Link to comment Share on other sites More sharing options...
