awoodman Posted May 28, 2010 Report Share Posted May 28, 2010 I have tightened the hose clamps to the max yet they still drip. The fittings (thru-hull boat fittings) are barbed and the hose went on real tight but still leaks. What would be a good resilient sealant to use,not glue? Quote Link to comment Share on other sites More sharing options...
Dnepr Dave Posted May 28, 2010 Report Share Posted May 28, 2010 I have had good luck heating the hose with an electric heat gun and clamping the hose while it's still warm and soft. I also use two hose clamps/connection. Dave Quote Link to comment Share on other sites More sharing options...
Roger Posted May 28, 2010 Report Share Posted May 28, 2010 I have had good luck heating the hose with an electric heat gun and clamping the hose while it's still warm and soft. I also use two hose clamps/connection. Dave Spread a little Magilube on there also. Not only will it go together easier but it will allow it to seal better. Quote Link to comment Share on other sites More sharing options...
