Barbed Hose Fitting Leak
I have tightened the hose clamps to the max yet they still drip. The fittings (thru-hull boat fittings) are barbed and the hose went on real tight but still leaks. What would be a good resilient sealant to use,not glue?
I have had good luck heating the hose with an electric heat gun and clamping the hose while it's still warm and soft. I also use two hose clamps/connection.
Dave
Dave
Spread a little Magilube on there also. Not only will it go together easier but it will allow it to seal better.
