mat300z Posted May 19, 2010 Report Share Posted May 19, 2010 Does anybody know the measurements for Hot Springs Sovereign Spa Cover radius corner measurements? I know the cover is 93" X 80" but I am trying to order a new one and need the radius corner. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
david_bilton Posted May 19, 2010 Report Share Posted May 19, 2010 Does anybody know the measurements for Hot Springs Sovereign Spa Cover radius corner measurements? I know the cover is 93" X 80" but I am trying to order a new one and need the radius corner. Any help would be appreciated. trace your corner out on a piece of cardboard then use a carpenters square to get the radius if you google up AQUA SPA PAK catalogue it will show you how to do this good luck Quote Link to comment Share on other sites More sharing options...
Shaamus Posted May 19, 2010 Report Share Posted May 19, 2010 Since the early 90's, most Hot Spring spas have had an 11-12" radius on their corners. However, it's very important to double check with a physical measurement. Here's a link to a guide we have on it: measuring spa cover corners. Hope that helps. Quote Link to comment Share on other sites More sharing options...
JerimiahR Posted May 19, 2010 Report Share Posted May 19, 2010 Does anybody know the measurements for Hot Springs Sovereign Spa Cover radius corner measurements? I know the cover is 93" X 80" but I am trying to order a new one and need the radius corner. Any help would be appreciated. Before you order a hot tub cover online, determine whether you're using one of the Hot Spring branded cover lifters (The lifter mechanism actually screws into the cover). If you do, you either need find someone who can install the specialty brackets inside the cover, or order it directly through a Hot Spring dealer. Quote Link to comment Share on other sites More sharing options...
mat300z Posted May 24, 2010 Author Report Share Posted May 24, 2010 Does anybody know the measurements for Hot Springs Sovereign Spa Cover radius corner measurements? I know the cover is 93" X 80" but I am trying to order a new one and need the radius corner. Any help would be appreciated. Before you order a hot tub cover online, determine whether you're using one of the Hot Spring branded cover lifters (The lifter mechanism actually screws into the cover). If you do, you either need find someone who can install the specialty brackets inside the cover, or order it directly through a Hot Spring dealer. Don't have any kind of lifter mechanism on the spa for the cover but thanks to everybody for the info. If anybody out there wants to know the radius corner on a 1998 Hotsprings Sovereign I is 11 inches Quote Link to comment Share on other sites More sharing options...
