razoo125 Posted February 22, 2010 Report Share Posted February 22, 2010 I have a Cal Quest 2000 ozone generator, and the ozone light on the panel will not turn on anymore. The cartridge is several years old and needs to be changed. Will this have anything to do with the ozone display light refusing to come on? I don't want to buy a new cartridge if I need to buy a whole new ozonator. If I replace the cartridge, should the light come back on??? Thanks! Quote Link to comment Share on other sites More sharing options...
dlzc Posted February 23, 2010 Report Share Posted February 23, 2010 I have a Cal [Zone] Quest 2000 ozone generator, ... I don't want to buy a new cartridge if I need to buy a whole new ozonator. If I replace the cartridge, should the light come back on??? I have reviewed the manuals at www.calspas.com, and found that this unit is for portable spas, it is UV based, and depends on a solid state ballast (part of the cartridge). Replacing the cartridge *is* replacing ozone generator. The questions are: 1) is there a fuse that might be blown? 2) is it connected to a circuit that is hot (a lamp or fan turns on here)? 3) what size is your spa? If it is too large, you'll need a bigger unit anyway, working or not. I'd recommend calling Cal Spas, and asking them what is the largest spa they recommend this unit for, then deciding what to do. Quote Link to comment Share on other sites More sharing options...
Peteyboy Posted February 23, 2010 Report Share Posted February 23, 2010 If it's a UV ozone the bulb will only last about a year. You need to replace it whether it's burning or not. Invest in a CD ozone. Quote Link to comment Share on other sites More sharing options...
hrustar Posted February 23, 2010 Report Share Posted February 23, 2010 If it's a UV ozone the bulb will only last about a year. You need to replace it whether it's burning or not. Invest in a CD ozone. I believe the light will turn back on. I have a CalSpa and was told the light not working is what informs you it's time to replace the cartridge. I think it's only $40. Quote Link to comment Share on other sites More sharing options...
razoo125 Posted February 26, 2010 Author Report Share Posted February 26, 2010 If it's a UV ozone the bulb will only last about a year. You need to replace it whether it's burning or not. Invest in a CD ozone. I believe the light will turn back on. I have a CalSpa and was told the light not working is what informs you it's time to replace the cartridge. I think it's only $40. I bought a CD ozonator and wil install it when it comes in. Does anyone know if the ozone light on the control panel will come back on even though I am replacing a UV OEM with a CD aftermarket? Just want to know if my light will come back on the display. Thanks! Quote Link to comment Share on other sites More sharing options...
razoo125 Posted March 1, 2010 Author Report Share Posted March 1, 2010 If it's a UV ozone the bulb will only last about a year. You need to replace it whether it's burning or not. Invest in a CD ozone. I believe the light will turn back on. I have a CalSpa and was told the light not working is what informs you it's time to replace the cartridge. I think it's only $40. I bought a CD ozonator and wil install it when it comes in. Does anyone know if the ozone light on the control panel will come back on even though I am replacing a UV OEM with a CD aftermarket? Just want to know if my light will come back on the display. Thanks! does anyone know? Quote Link to comment Share on other sites More sharing options...
Peteyboy Posted March 1, 2010 Report Share Posted March 1, 2010 I don't know - I never trust indicator lights - I smell for the ozone. Quote Link to comment Share on other sites More sharing options...
Dr. Spa Posted March 1, 2010 Report Share Posted March 1, 2010 Which most people can smell at only 2 parts per billion....far less that what's required to have any alleged effect on a spa Quote Link to comment Share on other sites More sharing options...
