bry21317 Posted December 16, 2009 Report Share Posted December 16, 2009 I had a power glitch that kept happening in my neighborhood this past Saturday, what happened was the power would go about for about 20 seconds every 15 minutes, this went on for about 3 hours. Once everything stabilized, I went out to put some chlorine in the tub, and noticed that the ozone was no longer working. I unhooked it, and it seems that water backed up into it, even though it was mounted higher than the Water Level. Now I thought everything else was working ok, but its not. It seems that my Circulation Pump, Silent Flo 5000, is not pumping either. So now the heater is tripping the Hi Limit switch. The tub is a 98 Hot Springs Grande Model. Both of the Jet pumps are working fine, but the circ pump does not seem to be doing anything. I took the panel off the control box and I have 115 v going to the wires on the Pump, but the pump will get a lil warm but not much, I tried tapping it with a hammer as you would do for a car starter to see if it would start up, but still no go. I removed the filters and have them soaking now, they were not that bad, so that should not have causeed it. I pulled the hoses off both ends of the pump, they both flow water with quite a bit of pressure, so theres no clogs that I can find either. Is my pump shot? Or is there a way to take this pump off and have it rebuilt or even see whats not working in it. It seems the motor is not turning, is my guess, so I think the power fried it, when it was glitching. Thanks, Bryan Quote Link to comment Share on other sites More sharing options...
AMG Posted December 16, 2009 Report Share Posted December 16, 2009 I had a power glitch that kept happening in my neighborhood this past Saturday, what happened was the power would go about for about 20 seconds every 15 minutes, this went on for about 3 hours. Once everything stabilized, I went out to put some chlorine in the tub, and noticed that the ozone was no longer working. I unhooked it, and it seems that water backed up into it, even though it was mounted higher than the Water Level. Now I thought everything else was working ok, but its not. It seems that my Circulation Pump, Silent Flo 5000, is not pumping either. So now the heater is tripping the Hi Limit switch. The tub is a 98 Hot Springs Grande Model. Both of the Jet pumps are working fine, but the circ pump does not seem to be doing anything. I took the panel off the control box and I have 115 v going to the wires on the Pump, but the pump will get a lil warm but not much, I tried tapping it with a hammer as you would do for a car starter to see if it would start up, but still no go. I removed the filters and have them soaking now, they were not that bad, so that should not have causeed it. I pulled the hoses off both ends of the pump, they both flow water with quite a bit of pressure, so theres no clogs that I can find either. Is my pump shot? Or is there a way to take this pump off and have it rebuilt or even see whats not working in it. It seems the motor is not turning, is my guess, so I think the power fried it, when it was glitching. Thanks, Bryan The silentflow 5000 is not even the current model anymore (in 2009 i think it's the e5). if you needed replacement, i would get the new model at http://www.backyardplus.com, they have been my source for everything for my 95' grandee. I read that calcium can get built up in them and take it out and smack it hard down on the flat end on the concrete (like your hammer tricK) and it can sometimes dislodge the built-up to allow it to start. either way, you probably would need replacing soon. i jusst replaced mine. good luck Quote Link to comment Share on other sites More sharing options...
Dan.The.Spa.Man Posted December 16, 2009 Report Share Posted December 16, 2009 AMG summed it up. Sometimes you can get them going again but even so it would not last long. Quote Link to comment Share on other sites More sharing options...
HockeyKat Posted December 16, 2009 Report Share Posted December 16, 2009 We had a pump go after some power issues (thunderstorm-related) as well. Same kind of symptoms. Sorry, but the only way to fix is replacement. Having it repaired would likely cost as much as a new one. Looks like you can get a replacement on ebay for about $125 or so, shipped. Quote Link to comment Share on other sites More sharing options...
bry21317 Posted December 16, 2009 Author Report Share Posted December 16, 2009 Thanks Guys. Dan.the.spa.man, I messaged you back. I am going to replace it to get it all back up and running. Thanks for all the input. Bryan Quote Link to comment Share on other sites More sharing options...
Dan.The.Spa.Man Posted December 17, 2009 Report Share Posted December 17, 2009 Thanks Guys. Dan.the.spa.man, I messaged you back. I am going to replace it to get it all back up and running. Thanks for all the input. Bryan You mentioned in the PM that you drained the tub to prevent freezing. You really should have blown it out as well...not sure if you did. If not, some water remains in the lines and will freeze. You may want to put a small lamp or automotive lamp in the motor compartment to keep the lines from freezing in there. Quote Link to comment Share on other sites More sharing options...
