AMG Posted December 11, 2009 Report Share Posted December 11, 2009 The tech at Watkins told me that while you can find the same DevCon epoxy online for cheaper, the stuff that I get through them with their repair kits is *special*. He said it is a special formula to work with chlorinated water. Is this really true? Do I need to be paying extra for this? If it is true, then I have no choice, but otherwise if it is BS, then I can buy DevCon elsewhere for cheaper. Quote Link to comment Share on other sites More sharing options...
JerimiahR Posted December 11, 2009 Report Share Posted December 11, 2009 I'm honestly not sure, however a good point of contact would be DevCon. http://www.devcon.com/contact/ Technical Service: 800-933-8266 Customer Service: 800-626-7226 You can at least ask them if their normal DevCon kit is designed to withstand Chlorine and other corrosives. Quote Link to comment Share on other sites More sharing options...
AMG Posted December 11, 2009 Author Report Share Posted December 11, 2009 I'm honestly not sure, however a good point of contact would be DevCon. http://www.devcon.com/contact/ Technical Service: 800-933-8266 Customer Service: 800-626-7226 You can at least ask them if their normal DevCon kit is designed to withstand Chlorine and other corrosives. Good call. I sent them a message on their Contact form. I'll post here with what they say. Quote Link to comment Share on other sites More sharing options...
reeffreak Posted December 23, 2009 Report Share Posted December 23, 2009 Pretty sure it's Devcon DA291, which is a plastic bonding adhesive. $12 online. HP250 would do it too, but its a 2:1 mix, I think it needs a special gun and it's a little more expensive. Just about any epoxy you buy will be corrosion resistant at the chemical exposure levels we're talking about in a hot tub. Levels aren't that much higher than ordinary drinking water. Peel strength / hardness / UV resistance are another story though. Whatever you do, don't buy the junk at the hardware store. Stick with what Devcon recommends, which will be an industrial product. Quote Link to comment Share on other sites More sharing options...
