Rbee1796 Posted September 12, 2009 Report Share Posted September 12, 2009 My Daughter had a party and ran the lights with the stereo for quite a while now its lights out. The lights around the jet control works just no LED's anyone else have this problem if so what was the cause Cheers Quote Link to comment Share on other sites More sharing options...
soakerguy Posted September 12, 2009 Report Share Posted September 12, 2009 If you open the cabinet door under the control panel you will see the light, Check the connection at the back of th light and also the spa pac connection to see if it is all connected securely. Quote Link to comment Share on other sites More sharing options...
Roger Posted September 13, 2009 Report Share Posted September 13, 2009 If you open the cabinet door under the control panel you will see the light, Check the connection at the back of th light and also the spa pac connection to see if it is all connected securely. PLease turn the power off before you start messing with electrical connections. Unless your comfortable working with electricity. Quote Link to comment Share on other sites More sharing options...
