FloridaGuy Posted August 5, 2009 Report Share Posted August 5, 2009 If you need to choose between the D1 line ChaimanII or the apparently substantially similar Marquis Show or Epic, which one would you go with and why? One other possible option is the top of the line Jacuzzi... 470 or 480. I would really appreciate feedback... first time buyer with a literal few dealers within 2 hours driving. Thanks. Quote Link to comment Share on other sites More sharing options...
BB512 Posted August 5, 2009 Report Share Posted August 5, 2009 I just bought the Marquis Show today after looking for over a year. I feel the quality of this spa is every bit as good as the other quality spa companies out there. And best of all feature to feature at a much better price. Good luck on your venture in finding the right spa for you. Quote Link to comment Share on other sites More sharing options...
d1dennis2009 Posted August 5, 2009 Report Share Posted August 5, 2009 I just bought the Marquis Show today after looking for over a year. I feel the quality of this spa is every bit as good as the other quality spa companies out there. And best of all feature to feature at a much better price. Good luck on your venture in finding the right spa for you. You definitely should consider wet testing any spa you plan to purchase, the Chairman II is a great spa and I'm sure that it would exceed your expectations. It has been an extremely durable and reliable tub for many years. I would suggest you do your research an select the spa the best fits your needs. Choose D1 Spas, you wont be disappointed..! Dennis Porter Quote Link to comment Share on other sites More sharing options...
THE SPA GUY Posted August 5, 2009 Report Share Posted August 5, 2009 I would agree dennis , wet test, wet test , wet test, but you cannot go wrong with the Chairman... Quote Link to comment Share on other sites More sharing options...
Markee Posted August 6, 2009 Report Share Posted August 6, 2009 Definitely wet test the Show. You will be amazed by the power that this thing puts out. It's got an incredible list of features, and be sure to open up the equipment compartment, you will be impressed! On a side note; the Epic has been the #1 top selling Marquis model for the past 3 years...another very nice tub. Quote Link to comment Share on other sites More sharing options...
THE SPA GUY Posted August 7, 2009 Report Share Posted August 7, 2009 Definitely wet test the Show. You will be amazed by the power that this thing puts out. It's got an incredible list of features, and be sure to open up the equipment compartment, you will be impressed! On a side note; the Epic has been the #1 top selling Marquis model for the past 3 years...another very nice tub. like wise with the D1 Chairman and how adjustable it is. also the chairman has the dynamic massage sequencer on the lounger, 6 preprogrammed massages up and down the body, if you open up the panel on the D1 you will impressed likewise the Marquis, also the chairman has the low amp 24 hour circulation pump to keep the water circulatiing and injecting the ultrappure ozone system, not just 2 hours every 12 which works just fine...., an likewise the chairman has been the best seller for D1 and i believe the Amore bay is doing really well/....but either way both are great companies , great backed spas....but i would definately wet test both and check out your local dealers..... Quote Link to comment Share on other sites More sharing options...
spatech (the unreal one) Posted August 7, 2009 Report Share Posted August 7, 2009 Definitely wet test the Show. You will be amazed by the power that this thing puts out. It's got an incredible list of features, and be sure to open up the equipment compartment, you will be impressed! On a side note; the Epic has been the #1 top selling Marquis model for the past 3 years...another very nice tub. like wise with the D1 Chairman and how adjustable it is. also the chairman has the dynamic massage sequencer on the lounger, 6 preprogrammed massages up and down the body, if you open up the panel on the D1 you will impressed likewise the Marquis, also the chairman has the low amp 24 hour circulation pump to keep the water circulatiing and injecting the ultrappure ozone system, not just 2 hours every 12 which works just fine...., an likewise the chairman has been the best seller for D1 and i believe the Amore bay is doing really well/....but either way both are great companies , great backed spas....but i would definately wet test both and check out your local dealers..... From above you can see both models have their proponents so assuming the deals are similarly enticing, both dealers seem fine and you like what you see in each - let the wet test be your guide. Quote Link to comment Share on other sites More sharing options...
THE SPA GUY Posted August 7, 2009 Report Share Posted August 7, 2009 Definitely wet test the Show. You will be amazed by the power that this thing puts out. It's got an incredible list of features, and be sure to open up the equipment compartment, you will be impressed! On a side note; the Epic has been the #1 top selling Marquis model for the past 3 years...another very nice tub. like wise with the D1 Chairman and how adjustable it is. also the chairman has the dynamic massage sequencer on the lounger, 6 preprogrammed massages up and down the body, if you open up the panel on the D1 you will impressed likewise the Marquis, also the chairman has the low amp 24 hour circulation pump to keep the water circulatiing and injecting the ultrappure ozone system, not just 2 hours every 12 which works just fine...., an likewise the chairman has been the best seller for D1 and i believe the Amore bay is doing really well/....but either way both are great companies , great backed spas....but i would definately wet test both and check out your local dealers..... From above you can see both models have their proponents so assuming the deals are similarly enticing, both dealers seem fine and you like what you see in each - let the wet test be your guide. well put......... Quote Link to comment Share on other sites More sharing options...
FloridaGuy Posted August 12, 2009 Author Report Share Posted August 12, 2009 Thanks to all of you contributers... I think i am going with the Marquis Epic, signature edtion. Any reactions to the proposed price of 9500. to include the stairs, cover, lift, delivery and set up? Quote Link to comment Share on other sites More sharing options...
