seau45 Posted July 22, 2009 Report Share Posted July 22, 2009 whats is the best lube to use when installing shaft seals? is it the p-80 rubber lubricant? thanks Quote Link to comment Share on other sites More sharing options...
coppersnowblue Posted July 22, 2009 Report Share Posted July 22, 2009 Not sure if its right but I use dish soap and has always worked well. Quote Link to comment Share on other sites More sharing options...
txpoolguy Posted July 22, 2009 Report Share Posted July 22, 2009 Lubricant should not be used when installing shaft seals. The instructions for the seals suggest not even touching the sealing area as the oil on your finger can contaminate and prevent a good seal. Imagine what lubricant can do. As Copper says, a small dot of dish soap allows the seal to be insalled easily, but rinses away so the shaft seal can operate correctly. Quote Link to comment Share on other sites More sharing options...
seau45 Posted July 23, 2009 Author Report Share Posted July 23, 2009 Lubricant should not be used when installing shaft seals. The instructions for the seals suggest not even touching the sealing area as the oil on your finger can contaminate and prevent a good seal. Imagine what lubricant can do. As Copper says, a small dot of dish soap allows the seal to be insalled easily, but rinses away so the shaft seal can operate correctly. thanks for the response.i noticed in the instructions u.s. seal recommends p-80 lube rubber lubricant which is why i had this question.I do know touching the white part is a big no no Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted July 23, 2009 Report Share Posted July 23, 2009 I use magic lube with teflon. No petroleum based lubes. Use VEEEEERY little on the boot of the porcelain side, and on the rubber on the seal side where it slides on the shaft / impeller. All you have to do is touch the opening of the lube tube, and thats enough. You already know, nothing on the seal surfaces. Quote Link to comment Share on other sites More sharing options...
quantumchromodynamics Posted July 23, 2009 Report Share Posted July 23, 2009 My preference is to use aquarium silicone sealant and let it dry overnight. That way the seals are very secure. Quote Link to comment Share on other sites More sharing options...
