Surfbeast Posted May 24, 2009 Report Share Posted May 24, 2009 Hey all, Got the tub up and running. Ran fine a few weeks but I got an Overheat message so I turned the tub off at the breaker. Next day the tub would kick the breaker as soon as I turned it on. I checked everything and found that when I disconnected the heater( two leads on the tube ) the tub ran fine ( Blower,pumps,lights ) Hook the heater bak up and the breaker kicks again. So, is the heater element bad or something else? Thanks! Quote Link to comment Share on other sites More sharing options...
ps558 Posted May 24, 2009 Report Share Posted May 24, 2009 Hey all, Got the tub up and running. Ran fine a few weeks but I got an Overheat message so I turned the tub off at the breaker. Next day the tub would kick the breaker as soon as I turned it on. I checked everything and found that when I disconnected the heater( two leads on the tube ) the tub ran fine ( Blower,pumps,lights ) Hook the heater bak up and the breaker kicks again. So, is the heater element bad or something else? Thanks! You need a new heater Quote Link to comment Share on other sites More sharing options...
