James141 Posted May 13, 2009 Report Share Posted May 13, 2009 I know you shouldnt put tablets directly in the skimmer but is it ok to put a small floater with bromine tablets in the skimmer? Quote Link to comment Share on other sites More sharing options...
Yoshi Posted June 13, 2009 Report Share Posted June 13, 2009 I know you shouldnt put tablets directly in the skimmer Why we shouldn't? Quote Link to comment Share on other sites More sharing options...
djousma Posted June 18, 2009 Report Share Posted June 18, 2009 I know you shouldnt put tablets directly in the skimmer but is it ok to put a small floater with bromine tablets in the skimmer? I have done it in the past, no problems. However, they do dissolve much quicker with a steady flow going over them all the time. A floater contols the speed by opening or closing. I just take the floater out while we are in it, so that it doesnt annoy anyone. Quote Link to comment Share on other sites More sharing options...
RuBaDuB Posted June 18, 2009 Report Share Posted June 18, 2009 I know you shouldnt put tablets directly in the skimmer but is it ok to put a small floater with bromine tablets in the skimmer? You can do it if you want, but they will dissolve way too fast and cost you more $, not to mention possibly having bromine levels higher than needed. Quote Link to comment Share on other sites More sharing options...
Hillbilly Hot Tub Posted June 18, 2009 Report Share Posted June 18, 2009 No, do not put bromine into the skimmer or the floater into it. Bromine has a very low PH and you are putting high concentrations of it that goes directly to your pumps and heater, you want this to dissipate in the water so you do not damage the equipment. If the floater is bother you while you are using the tub, remove it, just remember to put it back in after. Quote Link to comment Share on other sites More sharing options...
James141 Posted June 19, 2009 Author Report Share Posted June 19, 2009 No, do not put bromine into the skimmer or the floater into it. Bromine has a very low PH and you are putting high concentrations of it that goes directly to your pumps and heater, you want this to dissipate in the water so you do not damage the equipment. If the floater is bother you while you are using the tub, remove it, just remember to put it back in after. I see what you are saying but surely it is no worse than an inline bromine feeder? Quote Link to comment Share on other sites More sharing options...
Hillbilly Hot Tub Posted June 19, 2009 Report Share Posted June 19, 2009 As a service company, not a big fan of those either depending on how they are plumbed. Heater elements and pump seals have to be replace much sooner and more frequently on those tubs from what we have seen, most new tubs the inline feeders are now after going through the pumps and heaters, so thats ok. Quote Link to comment Share on other sites More sharing options...
James141 Posted June 22, 2009 Author Report Share Posted June 22, 2009 Ok thanks for the help, back in the tub the floater goes Quote Link to comment Share on other sites More sharing options...
