Cya Too High But Cant Drain Pool
Hi, I'm new here but I hope that you can help me with a problem. I have an 8000 gallon pool in the South of Spain that has been behaving itself for 4 years or more. As is the practice in Spain chlorine is administered via Trichlor tablets and water chemistry is checked using OTO test kits.
Having read on this forum and others the importance of FC I got hold of some 6in1 test strips. All seems OK with the exception of CYA which seems to be about 300ppm. I recognise that this far from ideal but the refilling of pools is strictly prohibited in Spain due to water shortages. This being the case I have would like to only add chlorine without CYA until the CYA level is reduced through backwashing etc, however, I expect that this will take sometime.
From what I have read here I see that high levels of CYA reduce the effectiveness if chlorine which raises a couple of questions:
1. What level of FC would I need to maintain to counteract the high CYA level.
2. What level of FC is safe for swimming
Have you been using any algaecide or phosphate remover or do you have metal ions (copper or silver) in your pool? If not, then you are fortunate you do not have algae growth and probably have low nitrates or phosphates.
To prevent algae growth using chlorine alone you want the FC to be 7.5% of the CYA level or higher -- absolute minimum at all times is 5%. That would be 15 ppm if the CYA is truly 300 ppm. This is technically equivalent to a pool with 0.05 ppm FC and no CYA so is quite safe for swimming, but you wouldn't want to drink large amounts of the water (not that you would). It's probably more economical to just use a supplemental algaecide, such as PolyQuat 60, to prevent algae growth and not worry so much about the FC, just keeping it around 5 ppm or so in that case. Either that, or cross your fingers and hope that whatever has kept algae at bay so far will continue.
Richard
Richard
Hi Richard
Thanks for your reply and info. The CYA has been this high at least since last Sept when I first tested it with test strips, however, I cant get a very accurate reading as the colour is not identical to any on the colour chart but is closest to 300ppm so its a bit of a guess. I hadn't thought of it before but I will dilute the pool water and retest to see what I get before taking any action. I do have some algaecide in already as a preventative measure and at the moment the FC is off the scale somewhere, probably about 10 or 12ppm, because my pool maintenance guy has had the pump running for 7 hours a day and tabs in both skimmers but I am hoping it will come down soon. I did swim last week though and the water smelt and tasted quite normal.
You say that keeping the FC at 15ppm is safe if the CYA is high, I recognise that there is a relationship between the effectiveness of chlorine and CYA but is this the same for red eyes etc? I only ask because this is a rental property and I wouldn't want any punters complaining of bleached hair or peeling skin!! In any case I think I will keep the FC at about 5ppm and use algaecide as you suggest.
Mac
The chlorine/CYA relationship is real, but if you aren't sure of your CYA level then that's not so good. I suggest you get yourself a good test kit, the Taylor K-2006 you can get at a good online price here or the TF100 kit you can get here with the latter kit having 36% more volume of reagents so is less expensive "per test".
You can probably just have 10 ppm FC and be OK, especially since you have algaecide in the pool. However, stop using the chlorine tabs and use chlorinating liquid or bleach. With the tabs, you are only making the CYA problem worse. The following are chemical rules of fact that are independent of concentration of product or of pool size:
For every 10 ppm Free Chlorine (FC) added by Trichlor, it also increases Cyanuric Acid (CYA) by 6 ppm.
For every 10 ppm FC added by Dichlor, it also increases CYA by 9 ppm.
For every 10 ppm FC added by Cal-Hypo, it also increases Calcium Hardness (CH) by 7 ppm.
The high FC, independent of CYA, is an issue for drinking the water since the chlorine is released from the CYA. As for bleaching or effects on eyes or the effect on skin or hair, while in the water the reaction rates will be very slow as if the water had less than 0.1 ppm FC with no CYA, but when you get out of the water then evaporation on the swimsuit could concentrate the chlorine more and there will be more chlorine "capacity" to keep bleaching. So it's possible that there might be some more bleaching effect if someone is going in and out of the water frequently and having their swimsuit dried out in the sun each time. That's speculation, since I haven't heard of this happening, but it is possible.
I suspect no one will notice a difference since some pool services use 100 ppm CYA and raise the FC to 14 ppm weekly and their clients don't notice the high FC at all.
Richard
“No one can make you feel inferior without your consent.”
This quote from Eleanor Roosevelt is particularly helpful to consider as many of us find ourselves posting our resumes yet again because—despite the pervasive impact of today’s “retracting” economy—it can be easy to think it’s somehow your fault that you’ve re-entered the job market: to beat yourself up thinking, “If only I had done X,” or “If only I hadn’t said Y.”
The trouble with this is that this sense of personal failure has the potential to influence the way you begin to think about your former situation, making it still more difficult to talk about how and why you were let go. With this in mind, then, let’s look at some language you can use to ensure you end up on offense instead of defense.
The Foul Weather Friend Response
You’ve all heard the term, “fair weather friend,” to describe the person who’s always around when the sun is shining and the seas are calm. Unfortunately, foul weather friends also exist—people who miraculously show up in your life the day your divorce papers are delivered, when you find yourself in the emergency room, or during the planning of your parent’s funeral, but are somehow never free to come to your holiday party,
your child’s graduation, or your anniversary celebration. These psychic vampires generally open with, “What happened?” not “What can I do?” as their ultimate goal is not your well being, but instead detail-collecting in an effort to make themselves feel better about what’s going on in their lives, and the boost of self-importance they get from being “there for you.” You will also find they have time to spread your story far and wide.
wow gold
For this particular category I recommend keeping your explanation short and sweet. “Well, we got divorced.” Or, “Well, I got laid off.” That’s it. Further detail is unnecessary. Should they follow up with an, “Oh, I’m so sorry. Did you see it coming?” all you need to say is, ‘Thank you. Yes. (Or no) I appreciate your concern.” They are not entitled to more.
The Potential Employer Response
Obviously things become somewhat more complex when a potential employer asks about the reason behind your changed status. wow power leveling That said, I continue to recommend keeping the particulars of your situation to a minimum, and instead making a broader statement about the state of your industry, “Yes, a number of people in my area were also let go due to downsizing.
world of warcraft power leveling
As you know, my sector was hard-hit due to X, Y, Z” Or, “Yes, an inability to raise our third round of funding necessitated some cuts all around. As you know, venture capital is thin on the ground in this economy.” should suffice. Then use that as a springboard for talking about what you learned from the experience, and how you plan to apply that knowledge to your new position. “What I’ve discovered is that tackling challenges outside my comfort zone actually inspires me—I like a sharp learning curve. This is one of the primary reasons I came in to talk to you. I very much admire the diversified, hands-on approach you ask of your employees.” Or, “What I learned is the value of a good fundraiser, so that’s where I’ve put my energy in the intervening months—very few people look bored when you mention you know how to raise money. With regard to how I might raise money for you, I was thinking of X, Y, Z.”
As you, I started out using 6-1 test strips last year. My CYA results showed inaccurately high with the test strips. The Taylor K-2006 was about 100PPM lower and that's the one I believe:
Taylor K-2006.
Taylor also sells a kit just for CYA testing if you want to go that route.
K-1720
I'd go with K-2006, if nothing else, just for the FAS-DPD Chlorine tests.
I did partial drainings about 4-5 times a week last year to get my CYA down to about 120-150. It drove my wife crazy and she's worried I'm going to do it again this summer. (And I probably am)
