Gr8video Posted January 25, 2009 Report Share Posted January 25, 2009 Hi, I have a 1996 Dimension One spa that I've just replaced the flo/reed switch in (after getting a flo1 error). I'm still getting the flo1 error message. Any suggestions? Thanks in advance..... Quote Link to comment Share on other sites More sharing options...
cyroute Posted February 6, 2009 Report Share Posted February 6, 2009 Hi, I have a 1996 Dimension One spa that I've just replaced the flo/reed switch in (after getting a flo1 error). I'm still getting the flo1 error message. Any suggestions? Thanks in advance..... Do you have a circ. pump in that model? check to see if that is running. I have a 2000 D1 and had a flo error and was told its either the flow sensor or the circulation pump. Mine turned out to be the flow sensor. I also sometimes had to take the top part of the flow sensor off (unscrew it) and then screw it right back in for mine to work after a refill. My circ. pump runs 24/7. I have seen them on ebay for around 170.00. Aslo make sure the arrow on the flow sensor is pointing in the right water flow direction mine points to the right when installed. Do your pumps still work even with the error on? Also what model do you have? Joe Quote Link to comment Share on other sites More sharing options...
