Cavalier Posted January 20, 2009 Report Share Posted January 20, 2009 It's been quite a week keeping the spa hot in this winter weather. Over the course of a 2 week period I have learned quite a bit and solved one problem but another persists. The GFI kept tripping and by elimination I discovered the the blower causing the fault. Now the topside display and hence all control functions shutdown. The breaker / GFI are not tripped. To clear the fault I kill the breaker, wait awhile and reset it and all is well till another episode. I faithfully drain the spa, clean and rotate the filter every 4 months. I have 3 filters in rotation. We use the spa all year. I think the problem may be the HI TEMP switch. I took the the filter out and will see what happens in 24 hours. serial # OPTI 367235 I would appreciate any suggestions. Thank you Quote Link to comment Share on other sites More sharing options...
Cavalier Posted January 20, 2009 Author Report Share Posted January 20, 2009 Still turns off. The topside paner shows ---------- and the rest is blank, If I hit the breaker and turn it back on after 10 minutes all is well till the next event. Quote Link to comment Share on other sites More sharing options...
otis_skywalker Posted January 20, 2009 Report Share Posted January 20, 2009 Still turns off. The topside paner shows ---------- and the rest is blank, If I hit the breaker and turn it back on after 10 minutes all is well till the next event. Watch dog mode. 99% time it's the temp sensor. Quote Link to comment Share on other sites More sharing options...
Cavalier Posted January 21, 2009 Author Report Share Posted January 21, 2009 Still turns off. The topside paner shows ---------- and the rest is blank, If I hit the breaker and turn it back on after 10 minutes all is well till the next event. Watch dog mode. 99% time it's the temp sensor. I agree with your suggestion. After research and reading and trouble shooting the spa systems all indicators are the sensor. I will order a replacement Temp Sensor. Quote Link to comment Share on other sites More sharing options...
