Duck Man Posted September 1, 2006 Report Share Posted September 1, 2006 What is everyones opinion on MPS treatment with dichlor shocking? Quote Link to comment Share on other sites More sharing options...
ciderjack Posted September 1, 2006 Report Share Posted September 1, 2006 What is everyones opinion on MPS treatment with dichlor shocking? I would use dichlor for a sanitzer and MPS as a shock once a week. Quote Link to comment Share on other sites More sharing options...
Stevie Posted September 1, 2006 Report Share Posted September 1, 2006 Pls add 6 cups per 100 gallons... Quote Link to comment Share on other sites More sharing options...
Hot H2o Posted September 1, 2006 Report Share Posted September 1, 2006 I would use dichlor for a sanitzer and MPS as a shock once a week. ?? What is everyones opinion on MPS treatment with dichlor shocking? depends on the brand. some you can use 1 teaspoon mps before each use. dichlor small amt weekly; Pls add 6 cups per 100 gallons... Why so much? You're not familar with this at all. Ignorance isn't so bliss, is it. Quote Link to comment Share on other sites More sharing options...
ciderjack Posted September 1, 2006 Report Share Posted September 1, 2006 ?? Instead of regularly using MPS and dichlor as a shock. Dichlor is a sanitizer, MPS is not. Using MPS with dichlor as a shock is backwards. Quote Link to comment Share on other sites More sharing options...
Stevie Posted September 1, 2006 Report Share Posted September 1, 2006 Why so much? You're not familar with this at all. Ignorance isn't so bliss, is it. Just having some fun with my buddie duck man... He knows why! Quote Link to comment Share on other sites More sharing options...
Chas Posted September 1, 2006 Report Share Posted September 1, 2006 I have found that using MPS daily, or after each use, tends to raise the TDS pretty rapidly. If you change the water every four months that may not be an issue. But if you do - as was suggested above - swap Dichlor for daily use and then use MPS for a shock once a week or once a month it seems to work just fine. Quote Link to comment Share on other sites More sharing options...
waterbear Posted September 1, 2006 Report Share Posted September 1, 2006 I have found that using MPS daily, or after each use, tends to raise the TDS pretty rapidly. If you change the water every four months that may not be an issue. But if you do - as was suggested above - swap Dichlor for daily use and then use MPS for a shock once a week or once a month it seems to work just fine. Good advice, I concur! You can also skip the MPS and just shock with dichlor weekly (or whenever you show more than .5 ppm combined chlorine) if you are using dichlor daily to maintain your free chlorine level. I personally like to maintain a FC of between 4-6 ppm in a spa. MPS also has a tendancy to lower pH and 'eat up' total alkalinity somewhat more than dichlor does. Quote Link to comment Share on other sites More sharing options...
