wyocarey Posted November 11, 2008 Report Share Posted November 11, 2008 Need suggestions on an automatic pool cleaner for indoor, in ground pool. Looking for something quiet, that works on exhisting filter system and can clean a little dirt, algae, small bugs. Also, looking for something that I can throw in Friday night and be ready to swim Saturday morning - or just leave attached 30 days a month and let work when timer cycles the pump. Any help greatly appreciated - In-The-Swim always has the same ones and I'm thinking something less expensive since I'm not asking it to clean out leaves, twigs and blown in dirt. Thanks in advance!!! Mike in Casper, Wy Quote Link to comment Share on other sites More sharing options...
don pool Posted November 11, 2008 Report Share Posted November 11, 2008 Mike, Do you have a dedicated pool cleaner line in your pool or do you have to put the pool cleaner in the skimmer? Quote Link to comment Share on other sites More sharing options...
wyocarey Posted November 12, 2008 Author Report Share Posted November 12, 2008 Mike, Do you have a dedicated pool cleaner line in your pool or do you have to put the pool cleaner in the skimmer? I hook up the manual vacuum (on a pole) through the skimmer with an attachment. There is a valve in the bottom of the skimmer that i move to vacuum. Quote Link to comment Share on other sites More sharing options...
Discount Pool Supplies Posted December 3, 2008 Report Share Posted December 3, 2008 Sometimes you get what you pay for. You will be able to find very low cost cleaners for your in ground pool but if they don't clean your pool very good what did you save? Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted December 4, 2008 Report Share Posted December 4, 2008 The type of pool cleaner your describing would be a bit of over kill. If you don't want to do the cleaning manually as described above and money is not an issue, I recommend the Polaris line of cleaners. They make units that run with or without their own booster pump. Also, there is the aqua-bot, you literally "throw it in" and plug it in the wall...socket. Sounds scary huh? While I have little experience with them, The owners that have talked to like them. Quote Link to comment Share on other sites More sharing options...
hippy95 Posted January 25, 2009 Report Share Posted January 25, 2009 Maybe try a hayward pool vac ultra, connects straight to skimmer and a great cleaner. Quote Link to comment Share on other sites More sharing options...
coo6776 Posted January 30, 2009 Report Share Posted January 30, 2009 I agree with the last person, either a pool vac or a barracuda, they are the most reliable and economical. The Polaris 360 has a lot of expensive moving parts and the bags aren't cheap either. Depending on the pool, the dont usually move as fast either, and they wont pick up smaller debris unless you get the silt and sand bag, and by the way have fun emptying out the bags and playing with the velcro. And dont think about getting the aquabot, it will last you a couple of months if your lucky, its not nearly worth the $1000+. Go with the pool vac or the barracuda. Quote Link to comment Share on other sites More sharing options...
lonestar23 Posted February 1, 2009 Report Share Posted February 1, 2009 For an indoor pool, I agree with the last guys. Suction side cleaners is all you should consider (and Polaris's suction cleaners are not good.) Pool Vac, barracuda, G3, they all work off suction from your existing system and will clean up any fine debris which gets on the bottom. Polaris are awesome for larger debris. Aquabots apparently are king in NJ but ive seen too many problems operating in other climates. (I used to work on pool cleaners.) Quote Link to comment Share on other sites More sharing options...
