Deb04 Posted July 26, 2008 Report Share Posted July 26, 2008 I read somewhere that you shouldn't use dry acid in a SWG pool? Is that correct? If so, is it a huge prolem that I've already used some (less than 1/4 of a small bottle) in my pool? Thanks ---------------------- SWG 25,000 Gallons Vinyl IG Cartridge Filter Quote Link to comment Share on other sites More sharing options...
Strannik Posted July 26, 2008 Report Share Posted July 26, 2008 It's better not to use dry acid in any pool. It's not a huge problem if you did. Quote Link to comment Share on other sites More sharing options...
punkjay Posted July 27, 2008 Report Share Posted July 27, 2008 why cant you use dry acid in a swimming pool? (sodium bi sulphate)? Quote Link to comment Share on other sites More sharing options...
chem geek Posted August 1, 2008 Report Share Posted August 1, 2008 The reason is that high sulfate levels can affect some SWG cells. However, I've never heard exactly how high the sulfate level needs to be before there are any problems. Dry acid is sodium bisulfate and adds to sulfates in the water (sulfuric acid also adds to sulfates as does MPS non-chlorine shock). Muriatic Acid is Hydrochloric Acid so only adds to chloride (salt) and not to sulfates. Quote Link to comment Share on other sites More sharing options...
