Ralphyboy Posted July 21, 2008 Report Share Posted July 21, 2008 After breaking the connection to the pump the pump leaked. I tried to hold the o ring up in the top mounted connection with vasilene but at 100 degees the o ring must have slipped. Is there another type of material that will help the o ring to stay inplace while joining the connection? Are new o rings recomended everytime you break the connection? Quote Link to comment Share on other sites More sharing options...
Dr. Spa Posted July 21, 2008 Report Share Posted July 21, 2008 NEVER use vasilene on O rings. Vasilene is an oil based product and will degrade the material the O rings are made out of. Quote Link to comment Share on other sites More sharing options...
Roger Posted July 21, 2008 Report Share Posted July 21, 2008 NEVER use vasilene on O rings. Vasilene is an oil based product and will degrade the material the O rings are made out of. Use Magilube made specificly for those O rings in spas and pools. Or....KY jelly Quote Link to comment Share on other sites More sharing options...
Ralphyboy Posted July 25, 2008 Author Report Share Posted July 25, 2008 After breaking the connection to the pump the pump leaked. I tried to hold the o ring up in the top mounted connection with vasilene but at 100 degees the o ring must have slipped. Is there another type of material that will help the o ring to stay inplace while joining the connection? Are new o rings recomended everytime you break the connection? Thanks. I cleaned the ring and the land. Did a better job of positioning the tubing on the pump before tightniong the collar. NO leak Quote Link to comment Share on other sites More sharing options...
