couzin2000 Posted July 14, 2008 Report Share Posted July 14, 2008 I have been working on a tool for weeks now. It's a calculator of costs for the monthly/yearly consumption of a spa/hot tub. I want to have certain information input on one end, and the other end must produce results. I've been looking for help within many scientific communities, and I have managed to find many formulas that will permit me to calculate a part of the consumption. But somehow, something is wrong within the calculations, and I'm looking for assistance. Warning: this thread is not for the average run-of-the-mill discussion: I am looking for scientific data here. Many factors come into play here: temperature of the air, of the tub (shell), of the water, and at different times of the year. I have temperature data, so this is fine. Ozone generator, hp of the massagers, the filter's pump, and so on, all of those aspects are already calculated. However, I am looking for the data for heating the water. Since I'm not in the US (Quebec, Canada), temperatures here are different: July is warm with an average 19.8°C. January is snowy with -12.5°C on average. I've managed to calculate the consumption of heating water from x° to y°. In essence, here is the formula: Q(energy, in kWh) = (1.155e-3kWh/liter-°C, the heat coefficient) x volume of water (liters) x temp.differential (end temp - start temp, in °C) This gives me the consumption of elevating the water temp to the desired level. However, I can't figure out how to calculate the costs of maintaining the temperature constant. I've managed to calculate heat loss, but that gives me a value that is not consistent with the amount a spa should cost here in Quebec (which varies between 600$US to 1500$US per year). If anyone can give me some help here, it would be much appreciated. Here are some things you may wish to consider when calculating: the spa is always square; I do not calculate in-ground or above-ground; the cover is closed at all times when not in use; insulation is not a factor, and all spas have the same for this problem; I'm looking for kWh (kilowatthours), not joules or time to heat the tub. Thanks in advance for everything! Couzin2000 Quote Link to comment Share on other sites More sharing options...
couzin2000 Posted July 22, 2008 Author Report Share Posted July 22, 2008 Really??? NO ONE can help me here??? Quote Link to comment Share on other sites More sharing options...
Tom Posted July 22, 2008 Report Share Posted July 22, 2008 It's an incredilby complex calculation. A couple of years ago I did a similar topic as a Fermi problem (google it) with an Arctic Spa, but unfortunately lost it in a hard drive crash. I had PM'd it to a few people - anybody still got a copy? Quote Link to comment Share on other sites More sharing options...
Glid Posted July 22, 2008 Report Share Posted July 22, 2008 Really??? NO ONE can help me here??? Nope! Just a dumb guy sitting in a tub. I don't post on forums to think...Just look at some of my replies. Good luck on the formula. I just go and pay my electric bill. The money is just going to fly out the window anyway! You forgot the T-I-T factor. Time in Tub will be a variable with number of people and if someone is sick he might have a tempreture! Quote Link to comment Share on other sites More sharing options...
wylekioti Posted July 24, 2008 Report Share Posted July 24, 2008 I have been working on a tool for weeks now. It's a calculator of costs for the monthly/yearly consumption of a spa/hot tub. I want to have certain information input on one end, and the other end must produce results. I've been looking for help within many scientific communities, and I have managed to find many formulas that will permit me to calculate a part of the consumption. But somehow, something is wrong within the calculations, and I'm looking for assistance. Warning: this thread is not for the average run-of-the-mill discussion: I am looking for scientific data here. Many factors come into play here: temperature of the air, of the tub (shell), of the water, and at different times of the year. I have temperature data, so this is fine. Ozone generator, hp of the massagers, the filter's pump, and so on, all of those aspects are already calculated. However, I am looking for the data for heating the water. Since I'm not in the US (Quebec, Canada), temperatures here are different: July is warm with an average 19.8°C. January is snowy with -12.5°C on average. I've managed to calculate the consumption of heating water from x° to y°. In essence, here is the formula: Q(energy, in kWh) = (1.155e-3kWh/liter-°C, the heat coefficient) x volume of water (liters) x temp.differential (end temp - start temp, in °C) This gives me the consumption of elevating the water temp to the desired level. However, I can't figure out how to calculate the costs of maintaining the temperature constant. I've managed to calculate heat loss, but that gives me a value that is not consistent with the amount a spa should cost here in Quebec (which varies between 600$US to 1500$US per year). If anyone can give me some help here, it would be much appreciated. Here are some things you may wish to consider when calculating: the spa is always square; I do not calculate in-ground or above-ground; the cover is closed at all times when not in use; insulation is not a factor, and all spas have the same for this problem; I'm looking for kWh (kilowatthours), not joules or time to heat the tub. Thanks in advance for everything! Couzin2000 I know I should not get into this. My brain is at half power after my back injury. But I did not see "time" mentioned. Assuming heat loss were constant (not) you should have a frequency as a percent of time you would have to reheat. I would avoid getting into Constant temp but rather a "how long to heat 2 degrees divided by how long it takes to lose 2 degrees" . Sorry I dont even know where my thermodynamics, physics, etc books are any more. but maybe this will start a new thought. Quote Link to comment Share on other sites More sharing options...
