chantal0123 Posted July 7, 2008 Report Share Posted July 7, 2008 Good afternoon, I'm new to this board and I have to say...there's SO MUCH information on this site!! It's really great. I'm from Ontario Canada. I've been reading several posts on this board for months now...trying to figure out what to purchase, etc. It seems like we might have gotten an awesome deal! We purchased over the weekend a used hot tub - a 2000 Beachcomber 520. The seller used it for 3 years only and then got divorced, moved the tub 2+ times in the last 3-4 years and never set it up (cause he knew he was moving on a temporarily basis). Anyhow, they (he & his fiance) didn't think they would use it so decided to sell it. They were asking $1,000 and were garanteeing it's functionality or money back. It's in a good shape...never spent a winter outside (was in the house). The color is still bright (green), etc. Yes, there is some dust/sand & stuff around the jets and the drain...but nothing major. We got it for $500.00!! Woohoo! So now, the electrician will come & do the work needed...hopefully all will be well when we started it up! Here are my questions. We were considering contacting a Beachcomber distributor and having a specialist come on site to start it up. I just spoke to a local Spa dealer and said that to his knowledge, we don't need that as it's "fairly" a simple process. Question 1: Any recommendations on this first thought? By talking with her, I decided that the Chlorine system would be best as we're used to it with our pool. We never had a reaction to our pool, it's easier & it's cheaper. Question 2: Are my thoughts on Chlorine exact? Here's the process I was thinking & recommended by many to do: 1- Flush/Clean the pipes. Use the shop vac to suck up most of it. Then fill up the tub & use a Whirlpool Rinse (the stuff you use when you close your tub). Let it run for 2-3 hours and then drain. 2- Take out the jets/drain and clean them with water & vinegar (there is a bit of build-up on them). 3- Clean the tub with the spa stuff. Then, use the shine/wax stuff (forgot the name) and do the whole tub. 4- Put in new filter. Fill the tub & let it run for 24hrs (run = with jets or without???). 5- Bring a water sample to have it diagnosed (we have hard water). 6- Purchase & use the stuff recommended and start it up! Is this about right?? Thanks! Chantal Quote Link to comment Share on other sites More sharing options...
Roger Posted July 7, 2008 Report Share Posted July 7, 2008 Good afternoon, I'm new to this board and I have to say...there's SO MUCH information on this site!! It's really great. I'm from Ontario Canada. I've been reading several posts on this board for months now...trying to figure out what to purchase, etc. It seems like we might have gotten an awesome deal! We purchased over the weekend a used hot tub - a 2000 Beachcomber 520. The seller used it for 3 years only and then got divorced, moved the tub 2+ times in the last 3-4 years and never set it up (cause he knew he was moving on a temporarily basis). Anyhow, they (he & his fiance) didn't think they would use it so decided to sell it. They were asking $1,000 and were garanteeing it's functionality or money back. It's in a good shape...never spent a winter outside (was in the house). The color is still bright (green), etc. Yes, there is some dust/sand & stuff around the jets and the drain...but nothing major. We got it for $500.00!! Woohoo! So now, the electrician will come & do the work needed...hopefully all will be well when we started it up! Here are my questions. We were considering contacting a Beachcomber distributor and having a specialist come on site to start it up. I just spoke to a local Spa dealer and said that to his knowledge, we don't need that as it's "fairly" a simple process. Question 1: Any recommendations on this first thought? By talking with her, I decided that the Chlorine system would be best as we're used to it with our pool. We never had a reaction to our pool, it's easier & it's cheaper. Question 2: Are my thoughts on Chlorine exact? Here's the process I was thinking & recommended by many to do: 1- Flush/Clean the pipes. Use the shop vac to suck up most of it. Then fill up the tub & use a Whirlpool Rinse (the stuff you use when you close your tub). Let it run for 2-3 hours and then drain. 2- Take out the jets/drain and clean them with water & vinegar (there is a bit of build-up on them). 3- Clean the tub with the spa stuff. Then, use the shine/wax stuff (forgot the name) and do the whole tub. 4- Put in new filter. Fill the tub & let it run for 24hrs (run = with jets or without???). 5- Bring a water sample to have it diagnosed (we have hard water). 6- Purchase & use the stuff recommended and start it up! Is this about right?? Thanks! Chantal Yep thats about right. But let me make it simple for you. Hook it up, fill it up, turn it on. At this point you can check its functionality and operation. Then put in some plumbing cleaner/flush and a bunch of chlorine. Let it run for a day and drain, clean, rinse and refill. Great deal, soak away. Quote Link to comment Share on other sites More sharing options...
chantal0123 Posted July 8, 2008 Author Report Share Posted July 8, 2008 Yep thats about right. But let me make it simple for you. Hook it up, fill it up, turn it on. At this point you can check its functionality and operation. Then put in some plumbing cleaner/flush and a bunch of chlorine. Let it run for a day and drain, clean, rinse and refill. Great deal, soak away. Thanks Roger!! We're hoping that it will work...but we're also prepared to have some repairs too! But still hopeful that all will be ok!! Thanks for your help! Chantal Quote Link to comment Share on other sites More sharing options...
chantal0123 Posted July 12, 2008 Author Report Share Posted July 12, 2008 UPDATE: It's hooked up, and all is fine! EVEN THE LIGHT BULB IS STILL GOOD! haha I just went to a Beachcomber dealer to get filters and he couldn't believe the deal we got. They're worth almost 6k brand new! Pretty happy! By tomorrow night, we should be soaking away! Chantal Quote Link to comment Share on other sites More sharing options...
Roger Posted July 12, 2008 Report Share Posted July 12, 2008 UPDATE: It's hooked up, and all is fine! EVEN THE LIGHT BULB IS STILL GOOD! haha I just went to a Beachcomber dealer to get filters and he couldn't believe the deal we got. They're worth almost 6k brand new! Pretty happy! By tomorrow night, we should be soaking away! Chantal Be sure to sanitize your water during heat up. How was the PH? Quote Link to comment Share on other sites More sharing options...
chantal0123 Posted July 14, 2008 Author Report Share Posted July 14, 2008 Be sure to sanitize your water during heat up. How was the PH? Yep, we got those instructions from our spa dealer. We got our water tested and our PH was a bit high (but not too much). I had to purchase the PH Down & the Metal Guard (we have hard water - no water softener yet). We decided to go the Chlorine way since we already have a pool and are used to it. All is good!! We LOVE it! Did I say WE LOVE IT??? I went in around 7:30 tonight...and planning to go back just before bed!!! I think this will be part of our daily life from now on! Chantal Quote Link to comment Share on other sites More sharing options...
