Forty Putney B&B - VT Posted May 21, 2008 Report Share Posted May 21, 2008 We are going to be opening a new hot tub at our Bed and Breakfast and have been informed that we are required to keep a log of hourly testing of the chlorine /bromine , Ph and temperature. There has GOT to be an electronic device that will do this, but I haven't found anything. Has anyone had this problem or can anyone make any suggestions? Thanks, Tim Brady Forty Putney Road Bed and Breakfast Brattleboro, Vermont www.fortyputneyroad.com Quote Link to comment Share on other sites More sharing options...
q95 Posted May 22, 2008 Report Share Posted May 22, 2008 I don't have any good solution. But, if I were in your shoes, I'd go to some hotel, athletic club, etc (anyplace with a hot tub) and ask what they do. I can't imagine that they send someone out there every hour. I could see daily or 2x per day, but hourly ! Is that some state or local regulation ? Quote Link to comment Share on other sites More sharing options...
Dr. Spa Posted May 22, 2008 Report Share Posted May 22, 2008 I've seem commercial applications were the staff does in fact test and log the water hourly, but, there are electronic automated devices. Check with a commercial pool builder. Quote Link to comment Share on other sites More sharing options...
Forty Putney B&B - VT Posted May 22, 2008 Author Report Share Posted May 22, 2008 I don't have any good solution. But, if I were in your shoes, I'd go to some hotel, athletic club, etc (anyplace with a hot tub) and ask what they do. I can't imagine that they send someone out there every hour. I could see daily or 2x per day, but hourly ! Is that some state or local regulation ? You're telling me! It's a State law. It says that "The following shall be measured in each spa or tub at least hourly during the hours of operation: Disinfectant levels, pH, Temperature and should be within designated range or adjusted accordingly." Of course, Alkalinity and Hardness only need to be tested weekly. I have a few calls around to places with hot tubs, but most are part of larger pools etc and they may very well just have someone there testing the water. I was hoping that there was some electronic device that would log the info electronically. Or even an electronic tester of any kind. Tim Brady Forty Putney Road Bed and Breakfast Brattleboro Vermont Quote Link to comment Share on other sites More sharing options...
Hillbilly Hot Tub Posted May 23, 2008 Report Share Posted May 23, 2008 I don't have any good solution. But, if I were in your shoes, I'd go to some hotel, athletic club, etc (anyplace with a hot tub) and ask what they do. I can't imagine that they send someone out there every hour. I could see daily or 2x per day, but hourly ! Is that some state or local regulation ? You're telling me! It's a State law. It says that "The following shall be measured in each spa or tub at least hourly during the hours of operation: Disinfectant levels, pH, Temperature and should be within designated range or adjusted accordingly." Of course, Alkalinity and Hardness only need to be tested weekly. I have a few calls around to places with hot tubs, but most are part of larger pools etc and they may very well just have someone there testing the water. I was hoping that there was some electronic device that would log the info electronically. Or even an electronic tester of any kind. Tim Brady Forty Putney Road Bed and Breakfast Brattleboro Vermont We may be able to help you if we had more info. We are right up the road from Putney (Charlestown NH) and do commercial tubs. If we have the exact info, we can contact or commercial tub supplier to see if there is something that will work for you. Quote Link to comment Share on other sites More sharing options...
Strannik Posted May 24, 2008 Report Share Posted May 24, 2008 You might need something like AutoPilot Total Control SWG, it has the ability to measure and adjust ORP and pH. Although it doesn't log it as far as i know. Quote Link to comment Share on other sites More sharing options...
Jason G Posted May 27, 2008 Report Share Posted May 27, 2008 In my state all commercial pools and spas are required to have a CPO on staff(http://www.nspf.org/Two_Day_Class.html). No outside testing agents are allowed. Your local health department should offer the CPO class several times per year. I would recommend you contact your health inspector personnaly and ask if you can get away with only testing durring occupancy. He will tell you exactly what he will require. You should also consider getting an automated chemical feed system. $$$ but worth the maintenance time. Quote Link to comment Share on other sites More sharing options...
