nicdan Posted May 12, 2008 Report Share Posted May 12, 2008 Hello, I am new here and have a question. I have a Hayward super pump sp-1605z1-m 3/4HP volts 115/230. I need to replace the motor. Where is the best place to purchase and what type? Thanks for any help! Michelle Quote Link to comment Share on other sites More sharing options...
JOSH D Posted May 14, 2008 Report Share Posted May 14, 2008 Hello, I am new here and have a question. I have a Hayward super pump sp-1605z1-m 3/4HP volts 115/230. I need to replace the motor. Where is the best place to purchase and what type? Thanks for any help! Michelle depends on the filter. often times pump motors are overrated. if you have a small filter than replace the motor with the same 3/4hp. you can buy a full rated motor w an uped service factor of 1.25 or greater this equals about another .25 hp giving you a 1hp for the price of the 3/4hp. if the motor or pump was underrated--for instance you have a larger sgft. filter like 400sgft. cartridge or a fns 60 de than you may want to bump up the hp to something like a 1.5 or 2.0. Beware if you increase the hp more than the full rate you will need to change the impeller and diffuser as well. Quote Link to comment Share on other sites More sharing options...
George N Posted May 22, 2008 Report Share Posted May 22, 2008 Check out Electric Motor Warehouse. (www.electricmotorwarehouse.com) I got my last motor there. EMW is great to work with. GN Quote Link to comment Share on other sites More sharing options...
ps558 Posted May 24, 2008 Report Share Posted May 24, 2008 Check out Electric Motor Warehouse. (www.electricmotorwarehouse.com) I got my last motor there. EMW is great to work with. GN Ao smith's motor you need is model #ust 1072 that is a 3/4 hp Quote Link to comment Share on other sites More sharing options...
