dannyboy Posted April 29, 2008 Report Share Posted April 29, 2008 Hello, I seem to be the proud owner (maybe not according to the cal spa fans) of a free hot tub. My neighbor decided to give me his 2001 Cal Spa pneumatic 2200. After spending only 20 minutes in a successful move from his yard into mine I have some questions I hope you may be able to answer now I have stated looking at this thing and read all 33 pages of posts here. He mentioned there seemed to be a leak from the left hand heater pipe sleeve. This guy decided to just squirt glue in every crack he could find, but for some reason that didn't fix it . I have managed to remove all the glued PVC and have new sleeve joints for the heater flow through. Upon replacement, it will basically be a new plumbing job from the safety suction system to the flow through. The problem I have is that he also has offered the 240 wiring required from his garage but not until he moves so I have no way of powering this thing up. Is there a way to just fill the tub to check for leaks or has the motor got to be running to produce the normal pressure for them to be exposed? If I do fill it without the possibilities of power for about 3 weeks, will the water be useless and all stagnant? The way my neighbor has the power presently set is just a GFCI in the main circuit/breaker box in the garage then about 100ft of conduit to his tub. I live in Colorado so is this possibly acceptable? He had an electrician install this but I wonder if I require an additional sub panel located near the tub (or 10 foot form tub, 90 foot from panel box in garage). I was hoping that this thing would be super cheap (here's really hoping!!) and I could just mirror his setup as I have positioned the tub in exactly the same place as he had it. Saving on the cable/wire, the tub and the 50a GFCI breaker is a plus... One last question is that the sleeve on the heater flow through I have purchased was a split sleeve with a fairly large, clear rubber washer. On the PVC connection to it's left....the sleeve connector to the rest of the PVC, there is a thin rubber ring/washer. Which should I use.... The large clear washer that came with the split sleeve or the thin rubber one...? Just want to ensure I fix that leak. I'll put some photos up later to explain better. Thanks for any help you can give me on this. I'm hoping it's not going to be a major headache. If there are problems with it, as long as the liner has no cracks and is in good condition, it's salvageable (at a price).....right???? cheers dannyboy Quote Link to comment Share on other sites More sharing options...
dannyboy Posted April 29, 2008 Author Report Share Posted April 29, 2008 Oh, another question...can anyone tell me the difference between the 1100, 2200 & 3300 Cal Spa models? Mine is pneumatic so is this something that can be replaced one day for a fancy digital controller? thanks!! Quote Link to comment Share on other sites More sharing options...
cplarsen Posted April 29, 2008 Report Share Posted April 29, 2008 To be up to code these days, you need a shutoff by the spa. As for finding a leak, go ahead and fill it, wait a couple of days, then check for water. Then drain it again. You won't find a leak as fast as if it was under pressure, but it's the best you can do till you power it up. Quote Link to comment Share on other sites More sharing options...
