asharerin Posted April 14, 2008 Report Share Posted April 14, 2008 We are thinking of purchasing a 2005 Tiger River Sumatran. The current owner had it converted to 230V. We do not have a 230V line but would like to use 110V. Can we convert the spa back to 110V? Can we do that ourselves or would we need an electrician? Will there be a huge hole in the side of the tub where the 230V wiring went? Apparently the spa is in like new condition but the warranty cannot be transferred. What would be a fair price for this spa? Quote Link to comment Share on other sites More sharing options...
cplarsen Posted April 14, 2008 Report Share Posted April 14, 2008 No doubt you can. It would probably be just resetting the jumper and a new wiring harness (and yes, check with dealer or electrician first) The real question is, why would you want to? At 110v, you won't get any heat while the jets are going. Look at the specs, you'll be going to a 1500w heater on 110v from a 6000w heater on 230v. Spend a little extra up front to get the 230v put in, you'll be much happier in the long run. There's a reason the last guy upgraded it. Quote Link to comment Share on other sites More sharing options...
asharerin Posted April 14, 2008 Author Report Share Posted April 14, 2008 No doubt you can. It would probably be just resetting the jumper and a new wiring harness (and yes, check with dealer or electrician first) The real question is, why would you want to? At 110v, you won't get any heat while the jets are going. Look at the specs, you'll be going to a 1500w heater on 110v from a 6000w heater on 230v. Spend a little extra up front to get the 230v put in, you'll be much happier in the long run. There's a reason the last guy upgraded it. Thanks for the reply. Unfortunately our current house is ancient and it is going to cost north of $1500 to upgrade the electric and have the 230V installed. I prefer to soak without jets so that would not really be an issue. Quote Link to comment Share on other sites More sharing options...
Dan.The.Spa.Man Posted April 14, 2008 Report Share Posted April 14, 2008 No doubt you can. It would probably be just resetting the jumper and a new wiring harness (and yes, check with dealer or electrician first) The real question is, why would you want to? At 110v, you won't get any heat while the jets are going. Look at the specs, you'll be going to a 1500w heater on 110v from a 6000w heater on 230v. Spend a little extra up front to get the 230v put in, you'll be much happier in the long run. There's a reason the last guy upgraded it. Thanks for the reply. Unfortunately our current house is ancient and it is going to cost north of $1500 to upgrade the electric and have the 230V installed. I prefer to soak without jets so that would not really be an issue. You'll have no problem converting ity back to 110V. Sent you a PM. Quote Link to comment Share on other sites More sharing options...
