Nat Posted December 18, 2007 Report Share Posted December 18, 2007 I opened the cover without unhooking the rear cover straps, and one of the plastic male pieces broke. It appears that the strap is sewn into the cover. I did call the hot tub dealer (Hot Springs) and they have the replacement plastic catches. Anyone know how to unhook the strap from the cover so a new catch can be installed? Thanks. --Nate Quote Link to comment Share on other sites More sharing options...
East TX Spa Posted December 18, 2007 Report Share Posted December 18, 2007 Cut the plastic at an angle for more retention strength. Terminator Quote Link to comment Share on other sites More sharing options...
Shaamus Posted December 19, 2007 Report Share Posted December 19, 2007 I'm a cover manufacturer and we do sell the replacement kits like Hot Spring does. Terminator is correct in that that is the way to install them. However, at least take a look locally at an upholstery/cut-n-sew shop. It really needs to be sewn back on and it may be worth the small investment. For local customers, we usually charge around $15-$25 including new hardware depending on how many clips are broken. I don't see why a local shop would turn down a quick twenty bucks for a 20 minute job. Quote Link to comment Share on other sites More sharing options...
Nat Posted December 19, 2007 Author Report Share Posted December 19, 2007 Thank you for your replies. --Nate Quote Link to comment Share on other sites More sharing options...
Makita Posted May 11, 2008 Report Share Posted May 11, 2008 hello, I just broke my snaps doing the same thing. Is there something else I can do without cutting the strap? It seems as though there should be a piece that you could clip to the loop on the strap, and then insert into the thing on the side wall of the tub... also, the picture is gone, I am guessing that the strap was cut, the piece added, then the strap resewn.... Quote Link to comment Share on other sites More sharing options...
Dr. Spa Posted May 11, 2008 Report Share Posted May 11, 2008 It's not the strap that's cut, but the plastic male part of the buckle.... Quote Link to comment Share on other sites More sharing options...
