mike p Posted November 18, 2007 Report Share Posted November 18, 2007 I have a Key backyard Discovery Ecstasy 4 button control. There is 1 button for the pump. If I am in the hot tub i sometimes want to turn off the pump and sit in silence but I can't turn the circulation pump off. It goes to circulation pump then jets and does not turn off. The heater is not on either..the temp is fine. I have tried switching to sleep or economy and it still stays on. It find that it is off during parts of the day but I want the freedom to turn it off when I want when I'm in the tub. My handbook says the hot tub has a 2 hour filtration setting (i checked to make sure my setting is on F2, not 4 or 6)...which means it will circulate/pump for 2 hours every 12 hours. perhaps I was just in the tub during that 2 hour period? Will hot tubs not let you turn off pump if it is in its "filtration cycle? Thanks Quote Link to comment Share on other sites More sharing options...
wireman Posted November 18, 2007 Report Share Posted November 18, 2007 Mine is the same way. I suspect it's due to cheaper controls. I was sorta wondering if some of the control manufactures have some different programming they would let people try out. It's worth contacting your control manufacturer over. Quote Link to comment Share on other sites More sharing options...
biggz Posted November 18, 2007 Report Share Posted November 18, 2007 I have a Key backyard Discovery Ecstasy 4 button control. There is 1 button for the pump. If I am in the hot tub i sometimes want to turn off the pump and sit in silence but I can't turn the circulation pump off. It goes to circulation pump then jets and does not turn off. The heater is not on either..the temp is fine. I have tried switching to sleep or economy and it still stays on. It find that it is off during parts of the day but I want the freedom to turn it off when I want when I'm in the tub. My handbook says the hot tub has a 2 hour filtration setting (i checked to make sure my setting is on F2, not 4 or 6)...which means it will circulate/pump for 2 hours every 12 hours. perhaps I was just in the tub during that 2 hour period? Will hot tubs not let you turn off pump if it is in its "filtration cycle? Thanks Mike I Think if the tub is filtering the pump won't turn off until it's complete. Quote Link to comment Share on other sites More sharing options...
