I can't find the pool tile cleaning solution here where I am. Is there something else like soft scrub or something I can use instead?
Thanks.
Thanks.
found someone who sells.. Aqua Balance Acidic Tile Cleaner which is supposed to be for pool tiles. is this a pool tile cleaner?
Is this a trick question? If it says it's for pool tile....
sorry meant to say "is this a good tile cleaner" LOL typo..
Thanks. I found some cheaper tile cleaner for pool tiles. I'm good. Thanks. B)
Still not clear, does it say that it will clean pool tile? If so, give it a shot. Cleaning pool tile has baffled man since the beginning of time. Problem is there are a variety if things that get on pool tile, and no one product has been able to clean them all (that i know of).
  • 2 months later...
I am looking for this Aqua Balance Acidic tile cleaner, does anyone know where to get it?
<!--quoteo(post=99778:date=Feb 2 2010, 11:27 AM:name=Gavin)--><div class='quotetop'>QUOTE (Gavin @ Feb 2 2010, 11:27 AM) <a href="index.php?act=findpost&pid=99778"><{POST_SNAPBACK}></a></div><div class='quotemain'><!--quotec-->I can't find the pool tile cleaning solution here where I am. Is there something else like soft scrub or something I can use instead?
Thanks.<!--QuoteEnd--></div><!--QuoteEEnd-->
Stop! What you want is oil eater (enzymes). remove your over flow drain cover, use a piece of plastic, like a credit card and replace the drain cover. Then fill the pool and allow to circulate. You'll be amazed. And if youre not familiar with enzymes you'll fall in love, they eat everything, and you can not overdose them "natural chemistry" product line is loaded with enzymes. Don't be afraid to double dose! Do be prepared to do a filter service and enjoy the cleanest clearest pool on the block.
