pagal Posted August 29, 2007 Report Share Posted August 29, 2007 Must I shock my tub weekly even if I don't use it for 2-3 weeks. It's been hot here and we have not soaked lately. Water is clear, ph/alk are good. What do you suggest? Shock now or just before we start using it again? Thanks everyone. Quote Link to comment Share on other sites More sharing options...
Churchy Posted September 1, 2007 Report Share Posted September 1, 2007 Must I shock my tub weekly even if I don't use it for 2-3 weeks. It's been hot here and we have not soaked lately. Water is clear, ph/alk are good. What do you suggest? Shock now or just before we start using it again? Thanks everyone. Shocking is important.. but if no ones goes in it there is nothing to shock out of it. if you put in a light shock befor everyone goes in after 2-3 weeks you should be fine.. that is as long as you maintained a proper sanitizer level all that time. Ps.. make sure you always leave your cover off for at least 20 min after you shock. helps with gassing off the stuff out of the spa after shocking and will give you better results. Quote Link to comment Share on other sites More sharing options...
