Divrlou Posted August 27, 2007 Report Share Posted August 27, 2007 Is it OK to turn the diverter valve when the pumps are running at high speed, low speed or off? Quote Link to comment Share on other sites More sharing options...
jwillard Posted August 27, 2007 Report Share Posted August 27, 2007 Is it OK to turn the diverter valve when the pumps are running at high speed, low speed or off? Doesnt matter when you turn the diverter valve...it just might be a little harder to turn when pumps are running...but not much. Quote Link to comment Share on other sites More sharing options...
Brulan1 Posted August 27, 2007 Report Share Posted August 27, 2007 Is it OK to turn the diverter valve when the pumps are running at high speed, low speed or off? Yes, but it does put restriction on the valve itself after a while. Your probably better off turning the valves with the pump not running or on low speed. Quote Link to comment Share on other sites More sharing options...
