Creekside Posted November 22, 2023 Report Share Posted November 22, 2023 I have a 08 Hydropool hsc-675LE hot tub and have several jet gaskets drying out cracking and leaking. Is it worth changing out all jets and lines or is marine silicone enough to replace the dried out gaskets? There’s another leak toward the bottom I’m assuming another gasket. I’m worried about others starting to leak in the future which is why I’m considering replacing them all. The jets are currently the glue and clamp style with 3/4” water inlet and 3/8” air inlets on them. If I was set on replacing all jets, what is an economical choice of jet body/jet? TIA Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted November 22, 2023 Report Share Posted November 22, 2023 I normally don't cut any lines. Back off the large nut on the jet back and then push jet forward far enough to remove old seal then use marine grade silicone front and back then retighten the large nut. Be sure to remove old silicone on backside before re siliconizing it back in. Quote Link to comment Share on other sites More sharing options...
