smolloy Posted November 20, 2023 Report Share Posted November 20, 2023 I have an early 2000s Hot Springs prodigy which just recently developed a leak in the lens and in the wire connector for the rear control panel. The symptom is the heater will shut off with the two flashing lights. I unplugged the rear panel control panel wire from the main board and that solves that problem for now. But the lens leak still seems to be causing the heater some trouble. My question is why does the leak cause the heater to malfunction? Is there some sensor that detects water? is there someway I can work around replacing the lens until after winter? For example, another wire, I can unplug or something like that. I would like to just get my tub running so it won't freeze and crack in the cold winter months. That way I can address the problem during the summer. thank you Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted November 24, 2023 Report Share Posted November 24, 2023 The heater should not be effected by a leak unless electrical components are wet. Quote Link to comment Share on other sites More sharing options...
