Colindec Posted September 30, 2023 Report Share Posted September 30, 2023 Hi there, My Balboa heater element recently became faulty and I have been doing research around replacing it. The original supplier has come back saying they recommend replacing the whole spa pack, charging £950+ VAT for the parts and £200 labour. If only replacing the heater £322 inc. VAT + £200 labour. I honestly wasn’t expecting for the cost to be so high so I rather replace the heater myself as the tub works fine atm when the heater isn’t plugged in the board. Does anyone have experience sourcing the correct replacement heater for Balboa parts, it would be super helpful. I have attached pictures of the part labels (entire control unit + heater) Thank you in advance, Colin Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted September 30, 2023 Report Share Posted September 30, 2023 Can be DIY'd fairly easy. Just make sure to look down the tube and make sure the element is not touching the side walls of the heater tube. https://www.poolandspacentre.co.uk/products/spa-and-hot-tub-elements.html https://www.outdoorlivinghottubs.co.uk/products/balboa-heater-element-2kw Quote Link to comment Share on other sites More sharing options...
Colindec Posted October 3, 2023 Author Report Share Posted October 3, 2023 On 9/30/2023 at 11:57 PM, CanadianSpaTech said: Can be DIY'd fairly easy. Just make sure to look down the tube and make sure the element is not touching the side walls of the heater tube. https://www.poolandspacentre.co.uk/products/spa-and-hot-tub-elements.html https://www.outdoorlivinghottubs.co.uk/products/balboa-heater-element-2kw @CanadianSpaTech thank you for sharing, would you say there is no need to replace the entire heater? Just the element? many thanks, Colin Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted October 3, 2023 Report Share Posted October 3, 2023 6 hours ago, Colindec said: Just the element? Quote Link to comment Share on other sites More sharing options...
