Yanco Posted September 27, 2023 Report Share Posted September 27, 2023 I have a 2 year old Arctic Spa hot tub and I just finished troubleshooting a water flow issue. Turns out the filter bypass flapper valve broke off and was stuck at the face of the impeller. Is this thing even necessary or should I just leave it out? Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted September 27, 2023 Report Share Posted September 27, 2023 At 2 years is it not under Warranty? When the spa is filtering and running on low speed the spring loaded flapper is closed and water is pulled through the filter. When you hit the spa into high speed the flapper will open and draw the extra water needed to supply the pump through the returns in the foot well. If the flapper is missing you will have decreased filtration. It is not an expensive part but can be tricky to install with the limited working space. Can you run without it... Would likely depend on how much you use the spa and your water quality will tell you. Quote Link to comment Share on other sites More sharing options...
Yanco Posted September 27, 2023 Author Report Share Posted September 27, 2023 Thank you! Quote Link to comment Share on other sites More sharing options...
