Balboa board fuse for Jacuzzi J Pump
Power off... Remove the black and white wires from the expansion and power back up and test them for power when the pump indicator led is lit on the topside saying the pump should be running. If you get power there re-attach and disconnect the pump from the expansion board and test where the white and black wires would connect the pump to the expansion board. If you get power off the expansion board then you have a pump issue. If you don't the it's the fuse or the expansion board relay. Remove the expansion board and look on bottom for darkened areas or burnt marks by the relay. Follow the power... into the expansion board and out of the board.
