Cortex911 Posted June 14, 2023 Report Share Posted June 14, 2023 Hi, I've a gecko in.xe spa pack that went bad. The heater 240v relay burned. So I've replace the relay with an equivalent (TE CONNECTIVITY POTTER & BRUMFIELD / T9AS1D22-12). the spa work flawlessly afterward. 2 weeks later, the replaced relay burned too. Do you think it's a bad relay from the beginning or another component is faulty. What can cause 2 relay to blow in 1 month ? Note that my pump, light and everything is working great even if the relay is burned. It's only the heating that do not works here. No error code on display. Quote Link to comment Share on other sites More sharing options...
cranbiz Posted June 14, 2023 Report Share Posted June 14, 2023 Check the heater. Make sure the element is not touching the tube. Also test the high limit sensor. 2 Quote Link to comment Share on other sites More sharing options...
Cortex911 Posted June 19, 2023 Author Report Share Posted June 19, 2023 On 6/14/2023 at 11:15 AM, cranbiz said: Check the heater. Make sure the element is not touching the tube. Also test the high limit sensor. Thanks for the tips, i'll replace the relay then test the heater for those points. Quote Link to comment Share on other sites More sharing options...
