shimpster Posted February 17, 2023 Report Share Posted February 17, 2023 Hello, I'm finishing my lower level and before I have the drywall go up I want to run the proper electrical from my Sub-Panel to the exterior wall of the home where I plan on putting my equipment pad. I was going to pull 1 run of 125' 8/3 Type NM-B Cable with Ground. What do you think? Should be good, no need for 6/3?? My future plan is to install a Fiberglass pool, gas heat, auto cover, and booster pump for a pool cleaner. Thanks for any input. Quote Link to comment Share on other sites More sharing options...
LazyPineapple Posted February 20, 2023 Report Share Posted February 20, 2023 220v 50 amp service. Requires #6. Under a 100 ft run. you check what your spa requires. If you require a 50amp service over +100’. You will need #4 wire to make up for the voltage drop. Quote Link to comment Share on other sites More sharing options...
