Andyman Posted November 26, 2022 Report Share Posted November 26, 2022 Good morning. I’m having an issue with my gecko in.xe controller. Everything works excepts low speed pump. So because of that it’s not heating. Because heating and filtering go thru on low speed. When I press pump 1 for low speed I can hear a click but nothing happens. So I’m guess bad relay. I did the checks listed in the manual for verifying proper voltage and I’m not getting any. How hard is the relay replacement? I didn’t plan on spending 500$ on a new spa pack right now. Thank you Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted November 26, 2022 Report Share Posted November 26, 2022 It can be done DIY if you have the right tools and knowledge of how to de-solder and soldering. I normally send mine out and have them replace all the relays to freshen up the entire board but I have a guy that is local. A few youtube vids out there. Quote Link to comment Share on other sites More sharing options...
Andyman Posted November 26, 2022 Author Report Share Posted November 26, 2022 I have all the tools at work. I tore apart. The relay is cooked. So I only use 2 out of the 4 relays on the board. What are odds if they all match of swapping the relays? Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted November 26, 2022 Report Share Posted November 26, 2022 if they are unused and match go for it. Let us know how you make out. Quote Link to comment Share on other sites More sharing options...
Andyman Posted November 26, 2022 Author Report Share Posted November 26, 2022 So now I have low speed but not hi. Atleast it’s heating and filtering. I have high speed on the other seats. I must have gotten it to hot. Quote Link to comment Share on other sites More sharing options...
