Ron Streelman Posted July 23, 2022 Report Share Posted July 23, 2022 nordic retreat ms low volume pump won't turn off Quote Link to comment Share on other sites More sharing options...
cranbiz Posted July 25, 2022 Report Share Posted July 25, 2022 Probably a stuck relay. Do you have a multimeter and if so, know how to use it? Post up pictures of the spa pack, the wiring diagram usually found on the inside of the cover and of the equipment area. Relays are a common failure point. They are not expensive and can be replaced if you can solder. If not, a decent electronics repair shop can change them out. Quote Link to comment Share on other sites More sharing options...
