nordic retreat ms low volume pump won't turn off
Probably a stuck relay. Do you have a multimeter and if so, know how to use it?
Post up pictures of the spa pack, the wiring diagram usually found on the inside of the cover and of the equipment area.
Relays are a common failure point. They are not expensive and can be replaced if you can solder. If not, a decent electronics repair shop can change them out.
