Blowing fusible on a GECKO un.ye-5 - SPA Vortex
lolo77
Hello
The last year (2021) , my fusible in F2 location 20 Amp blowed .
After many troubleshooting , It was due to electrical short on the pump3 electric . We changed the pump3 and it was fixed .
Yesterday, My spa stopped.  I had another blowing on the same fusible F2 20Amp .
I cleaned my both filters regarding the circulation pump  and the jets and the spa is started again
According my calculations,  cir. pum take 0,65 Amp  + pump 3 take  15 Amp + the UV lamo fait take 1 Amp .
Is it correct ?
I am wondering if we can put 25 Amp instead  of 20 Amp on F2 location.
What do you think ?
Motherboard : GECKO un.ye-5-NA
Country : Canada (QC)
swim SPA : Vortex
F1 : Pump1
F2 : Cir,Pump + Pump3 + lamp UV
F3 : Pump2
lolo
SPA-circuit-electrique.pdf
I would not use a 25amp.
The 20 amp fuse is not normally pump related in my experience but I have not worked on many of the Y series packs yet. Post a photo of the schematic on the inside cover. You may want to contact Gecko tech support directly. They are usually very helpful. 1 800 784 3256 Let us know what you find out.
