lolo77 Posted June 28, 2022 Report Share Posted June 28, 2022 Hello The last year (2021) , my fusible in F2 location 20 Amp blowed . After many troubleshooting , It was due to electrical short on the pump3 electric . We changed the pump3 and it was fixed . Yesterday, My spa stopped. I had another blowing on the same fusible F2 20Amp . I cleaned my both filters regarding the circulation pump and the jets and the spa is started again According my calculations, cir. pum take 0,65 Amp + pump 3 take 15 Amp + the UV lamo fait take 1 Amp . Is it correct ? I am wondering if we can put 25 Amp instead of 20 Amp on F2 location. What do you think ? Motherboard : GECKO un.ye-5-NA Country : Canada (QC) swim SPA : Vortex F1 : Pump1 F2 : Cir,Pump + Pump3 + lamp UV F3 : Pump2 lolo SPA-circuit-electrique.pdf Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted June 29, 2022 Report Share Posted June 29, 2022 15 hours ago, lolo77 said: I am wondering if we can put 25 Amp instead of 20 Amp on F2 location. I would not use a 25amp. The 20 amp fuse is not normally pump related in my experience but I have not worked on many of the Y series packs yet. Post a photo of the schematic on the inside cover. You may want to contact Gecko tech support directly. They are usually very helpful. 1 800 784 3256 Let us know what you find out. Quote Link to comment Share on other sites More sharing options...
lolo77 Posted June 30, 2022 Author Report Share Posted June 30, 2022 Hello Thank for you update the schematic as attached Quote Link to comment Share on other sites More sharing options...
