Sourkeys Posted May 14, 2022 Report Share Posted May 14, 2022 Noticed water leaking all around base of hot tub l, finally took off panels and noticed the back right of hot tub this hose hanging down from the top of the tub and was full of water and water running out. I have another hose that looks like this on front left of hot tub but it's completely dry. Any ideas? Hot tub has worked fine for 10 months without issue. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted May 14, 2022 Report Share Posted May 14, 2022 Likely a one way check valve for the air injection that is no longer working and letting water get past. Made by Waterway Plastics 670-2270 1⁄2" S NEOPERL Check Valve with Cap/Foam https://hottubwarehouse.com/products/waterway-check-valve-670-2270 Quote Link to comment Share on other sites More sharing options...
Sourkeys Posted May 14, 2022 Author Report Share Posted May 14, 2022 2 hours ago, CanadianSpaTech said: Likely a one way check valve for the air injection that is no longer working and letting water get past. Made by Waterway Plastics 670-2270 1⁄2" S NEOPERL Check Valve with Cap/Foam https://hottubwarehouse.com/products/waterway-check-valve-670-2270 Thanks! Super helpful. Will look into getting it replaced Quote Link to comment Share on other sites More sharing options...
