Naimad Posted April 27, 2022 Report Share Posted April 27, 2022 Hello, I have a Sundance Denali 680 series spa from 2009. Today I noticed a leak coming from below and upon opening the panel, we found that the hose that connects to the motor from what I believe are the jets, was leaking water. I touched it and the entire thing fell down and started heavily squirting water. We capped it and drained the hot tub but now I don’t know what the best way would be to go about reattaching it and preventing further leaking. I’m not familiar with what type of connection this is. I’ve attached some photos. Please let me know if anyone needs any further photos or zoomed out! thank you in advance! Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted April 27, 2022 Report Share Posted April 27, 2022 https://www.poolandhottubdepot.com/pump-drain-plug-hose-barb-adaptor/?gclid=Cj0KCQjw06OTBhC_ARIsAAU1yOXZTc8tGnWvO2MkkL7wQ58NUa_j_TWMUAs5DsKku2c48vyL1yXnWC4aApLzEALw_wcB Verify with seller if it will fit your pump. Use a small flathead screwdriver in the hole to remove the part left in the housing and just back it out. The hose/barb size is 3/8" Quote Link to comment Share on other sites More sharing options...
