signalstan Posted November 15, 2021 Report Share Posted November 15, 2021 HI folks I need some help with my spa I just changed the water and every thing was running good and heating up I came back a few hours later to find the gfi tripped I unplugged all loads and sensors from the board then reset the gfi breaker the gfi trips only when i plug in the ribbon cable from the topside control panel leaving me wondering if its the control panel is bad or the main board Sundance spa capri #850 from 2005 Quote Link to comment Share on other sites More sharing options...
ciderjack Posted November 21, 2021 Report Share Posted November 21, 2021 When you unplugged all the loads, did you make sure to take the white circulation pump wire off the terminal block? The board and/or control panel is very unlikely to be the problem. 1 Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted November 22, 2021 Report Share Posted November 22, 2021 With everything connected, does the breaker trip immediately as you turn it on or run for a little while? How long? Quote Link to comment Share on other sites More sharing options...
