Bleach Method - How Often?
mscdman
For those using the Dichlor then bleach method like me how often are you adding bleach if not using the tub daily? Do you add in daily anyway?
Ive been adding after every use, usually every other day, bringing bromine to 6ppm.
but it drops to 1ppm by the time I use the tub the day after.   Are you all adding the bleach daily then to keep it consistent at some level?
last year I added bleach after each use to 12ppm so that on my off day there was still bromine but the issue then was that high that regular was eating away at the pillows.
thoughs?
