Balboa 2000LE system reading oh code
Lissa
I have a balboa 2000le system m7 sensors just replaced. Still getting ohh code after reaching 81 degrees had it set at 80 for testing. It shut off at 81 and read 81 for 5 mins then started flashing ohh. Any ideas what is going on with this?
Just to be clear, the voltage to the heater turned off, not the pump turned off? You used a voltmeter for this test?
Remove filter and try again. If it works, get a new filter.
Check pump inlet for obstructions. All sorts of stuff can get in there.
Test sensors with a digital ohm meter (set to 20k if adjustable) and post results.
